← All posts
Defense7 min readBy Rocket.Chat Content Team
Benefits of edge computing for mission critical communications in 2025
How processing data at the edge makes mission-critical communications faster and more resilient, plus five adoption strategies.
An operator with a radio and laptop in the field
Mission critical communications are essential for coordinating during emergencies - even a millisecond delay can disrupt operations. This is especially true in military drone missions, autonomous vehicles, and disaster response, and you know why.
Even programs like DARPA’s CODE aim to improve unmanned aircraft resilience in contested airspace by developing a modular software architecture.
However, critical missions cannot rely solely on centralized data centers. In a scenario where microseconds matter, and connectivity isn't guaranteed, edge computing is rapidly becoming the X factor in mission-critical environments. When you process data closer to the source, you can reduce bandwidth issues and improve reliability.
Let’s explore the benefits of edge computing for mission critical communications in 2025.
01Understanding edge computing in mission critical communications
__wf_reserved_inherit
The global edge computing market is on a steep rise. It was estimated at $60 billion in 2024 and is projected to hit $110.6 billion in 2029.
This is not just a trend. It's a response to the increasing demand for real-time, secure, and reliable data processing across critical infrastructures and defense.
What is edge computing
Instead of relying on distant cloud servers, edge computing solutions process data on-site and can operate with or without the Internet. Today's edge devices can process data as powerfully as full data centers could just five years ago.
By 2025, edge devices will handle massive amounts of data—over 90 zettabytes worldwide. This rapid growth is making possible new capabilities for mission critical systems that weren't available before.
Why it matters in mission critical communications
Traditional networks can’t handle huge volumes of data to operate military autonomous systems. In contrast, edge solutions can analyze data instantly and in real time.
For example, the US Army’s TITAN ground system can process sensor data from multiple sources in real time, enhancing situational awareness and precise targeting.
The system also uses AI and machine learning to reduce the sensor-to-shooter timeline so you can act faster in complex combat situations.
Do you remember Gartner’s insights on decentralization? Since 2018, enterprises have been moving away from centralized computing, with 10% of enterprise-generated data already processed outside traditional data centers.
By 2025, at least 75% of enterprises will adopt this approach. That’s why edge-driven solutions are considered the future of mission critical communications.
02Benefits of edge computing for mission critical communications
Edge computing makes mission critical communications more resilient. Here’s how it enhances operational efficiency across high-stakes industries:
1. Reduced latency
Latency is a major issue in mission critical communications. Edge computing delivers responses in 5ms or less—a requirement that traditional cloud systems simply can't match due to network congestion.
For example, the US DoD’s Project Maven applies AI and machine learning to automate the processing of vast amounts of full-motion video from intelligence, surveillance, and reconnaissance (ISR) assets.
However, data is processed in centralized data centers, enhancing intelligent analysis and not reducing real-time latency.
In contrast, Tesla’s autopilot uses edge computing to detect obstacles in real time. Similarly, China’s sixth-generation fighter jets are expected to integrate edge AI for rapid threat detection and UAV coordination.
2. Improved reliability
Centralized networks are vulnerable to evolving cyber attacks, power failures, and network outages. If a central command system goes down, you can’t communicate with anyone.
For example, the US Air Force’s ABMS uses a distributed network architecture for real-time data sharing across multiple domains. It uses cloud-based and AI-driven decision-making tools to enhance resilience.
However, edge solutions can operate independently in hostile environments, and it's a step higher than cloud. You can collaborate with external teams even when central networks fail.
3. Enhanced security
Transmitting sensitive data, even on private cloud networks, can be risky. Edge computing stores classified information locally, minimizing security risks.
For example, DARPA’s Blackjack program leverages a constellation of LEO satellites for real-time, encrypted data processing. These satellites use onboard processing systems, securing critical intelligence at the edge.
With edge computing, you don’t need to depend heavily on central networks for security.
4. Cost efficiency
Transmitting data to the cloud is expensive, especially for high-volume, real-time chat applications. Whereas, edge computing optimizes bandwidth use, lowering operational costs.
Mobile Edge Computing (MEC) is an effective option for military operations. It uses 5G and telecom networks, integrating edge servers within mobile base stations to optimize bandwidth and lower latency, and transmission costs.
5. Real-time insights and decision-making
For security screening at airports and federal facilities, AI-powered imaging and edge computing can help detect threats in real time and more accurately than traditional CT-based screening.
With edge, security data is processed instantly at checkpoints. Moreover, training AI models on raw imaging data can accurately detect explosives, fentanyl, and special nuclear materials, reducing manual inspections.
035 strategies to implement edge computing in mission critical communications
You need a strategic approach to implement edge computing elements in mission critical communications. Here are five ways to do it effectively:
1. Assess current infrastructure
Evaluate your existing communication systems and identify areas where edge computing can enhance performance.
The DoD has already integrated edge computing, AI, and advanced 5G networks into tactical operations to enhance operations at the edge.
Even the former DoD CIO John Sherman emphasized the use of operational edge capabilities for missions in high-risk environments. Staying ahead with innovative technology is no longer an option.
2. Develop a comprehensive edge strategy
Create a detailed plan to integrate edge into your operations.
For example, combining the Edge of Things (EoT) with a digital twin (DT) network can fortify your networks against evolving cyberattacks.
The EoT network connects smart devices and sensors, while the DT network creates a real-time digital replica of the edge layer, enabling rapid threat detection and adaptive security measures.
You can secure mission critical communications with this approach.
3. Invest in edge-compatible technologies
Adopt technologies that support edge computing, such as AI-driven analytics and IoT devices.
Remember Airspan? They partnered with Ecrio in 2024 to develop an AI-powered critical communication system for private 5G networks. This enables seamless human-to-human, machine-to-human, and human-to-machine interactions.
With AI and edge, you can detect and act on critical issues faster than ever before.
4. Prioritize security measures
Is your mission critical communications quantum ready? Implement robust security protocols to protect data processed at the edge.
Traditional cryptographic methods like RSA and ECC are vulnerable to quantum attacks, however, by combining classical and quantum-resistant algorithms, you can secure mission critical communications while transitioning to post-quantum cryptography.
5. Foster collaboration
You can effortlessly collaborate with any team in remote environments and challenging conditions.
A 2025 study highlights how integrating edge computing with Industrial Internet of Things (IIoT) environments improves data analysis speed and response times.
After implementing edge with IIoT, adding AI-driven anomaly detection, blockchain, and digital twins can further strengthen cybersecurity by detecting threats in real time.
04Rocket.Chat supports mission critical communications with edge-ready deployment
Rocket.Chat is an open-source, highly secure communication platform for real-time messaging and collaboration. Trusted by organizations like the U.S. Navy, British Columbia, and Elsäkerhetsverket, it supports classified networks such as NIPRNet and SIPRNet, making it ideal for mission critical environments.
Key features for edge-ready mission critical communications
Low-latency communication
Rocket.Chat’s architecture is optimized for real-time interactions. Its on-premise deployment minimizes reliance on external networks, ensuring faster response times.
On-premise deployment for maximum control
With self-hosting and private cloud options, you can deploy the platform in air-gapped environments, and operate in secure networks.
High security and compliance
Certified for ISO 27001 and SOC 2, Rocket.Chat aligns with U.S. federal zero trust principles, ensuring strict data protection and compliance.
Customizable and extensible
Rocket.Chat’s MIT Open Source License offers complete transparency and flexibility. You can customize the features, white label the platform, and use it for your specific needs.
The platform lets you expand operations without compromising security and performance.
05Final note
Edge computing solutions transform mission critical communications and ensure operations even in disconnected environments. Organizations in defense, public safety, and critical infrastructure rely on edge strategies to enhance security, speed, and resilience.
Using edge-ready deployment options like air-gapped servers and self-hosting, Rocket.Chat enables teams to collaborate securely with minimal reliance on external networks.
Explore edge-ready solutions to strengthen your communication infrastructure. Reach out to our team to learn more.
